Adding a meter | on ElectriciansForums
Discuss Adding a meter in the Talk Electrician area at ElectriciansForums.net
Wilts
Hi Guys,
Bit of advice please. I've been asked to quote to add a meter to a 12 way board in a warehouse. The job is pretty strait forward but am i right in saying, by doing this i will need to test the 12 way board after
Hi Guys,
What sort of meter? Presumably it'll be connected via CT's? If so then use split CT's you can retrofit and the only connections you make will be for the voltage connection so very little to test.
Hi Guys,
What sort of meter? and what will it be metering?
IT will be metering office space on the second floor. 63a supply
So your not adding metering to the whole DB, just one of the outgoing ways?
What type of metering? My earlier reply assumed it was metering for V, I, kW, kVA etc etc, or are you metering for kWh only?
Reply to Adding a meter in the Talk Electrician area at ElectriciansForums.net
P
16 Square Meter Domestic Bathroom Tiling Work Malton North Yorkshire I have a job in Malton North Yorkshire, and I’m giving it a try on here (you...
PETERHA
P
It sounds like the company involved in the works doesn't have the necessary expertise to undertake the task A company that specialises in this...
