Darren Wood
Hi All.
In our En-suite we have 3 MR16 downlighters, a bathroom cabinet( that incorporates two small halogen spot lights and a shaver socket, all controlled by a pull cord switch.
I would like to remove the pull cord switch and replace it with A Lightwave RF inline dimmer switch which is controlled remotely. The connections on the this are pretty basic live and neutral in and out and two earths.
I therefore thought that it was going to be simple job of wiring it up, however I just cant get my head around the wires in the loft and where to put this switch.
This photo shows the wires concerned. In summary there are 6 cables in total, one of these is 4 core the others are 3. 5 of the live wires all join in the terminal as can be seen and so do the earths and so do the neutrals.
My confusion is around the cable coming up from the bottom right of the photo which ran to the pull cord. The Black wire from this goes into the connector block in the middle of the photo and this then goes directly into another light fitting so this must be a live wire after the pull cord. That means that the red wire coming from that pull cord ( again wire coming from the bottom right of the photo ) is joining with all of the other red wires, this is the bit that is throwing me as surely this is the live before it goes into the switch, therefore surely there is a live feed going to all of the lights prior to the pull cord. Of course it may be that its perfectly ok to have a pull cord anywhere in the circuit ?
Ie i would suspect to see Live feed - into switch - into lights. Is it possible that its live feed - lights - switch ?
Can someone just help my telling me where in that bundle i wire in the new inline switch please. Any help really appreciated
The photo is on its side so when i refer to bottom right its actually right side top
Darren
Darren
