View the thread, titled "Adding electric to thin interior basement wall ( w/ furring strips)" which is posted in USA Electrical Forum on Electricians Forums.
It's common in the US to build interior basement walls on masonry using furring strips covered with sheet rock. Is there a proper way to add electical outlets to these walls and is it required by code?
Thanks, I'm thinking to use 2x4 as furring strips (really 1.5") & then 1/2" drywall will give me a total of 2" of depth. I can then use a product like the one below. Still not sure if I have to have outlets by code but but thinking I can either run wire down to each outlet or split the furring strips to leave space for wire to run between outlets (as in figure below) the former probably being the easier idea. View attachment 64684View attachment 64685
Be careful with shallow boxes because all garages, basements etc. have to be GFCI protected and you will not be able to fit the receptacle in the box plus the wires. Your option is to use GFCI breakers
Reply to the thread, titled "Adding electric to thin interior basement wall ( w/ furring strips)" which is posted in USA Electrical Forum on Electricians Forums.
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical
forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
