Adding extra double socket to garage | Page 2 | on ElectriciansForums
Discuss Adding extra double socket to garage in the DIY Electrical Advice area at ElectriciansForums.net
At least it's got a grommet fitted, more than most have...
I thought at first it was ‘all round band’, but looking again, it’s something else.
Yeah, us industrial bashers use proper stuff.
What about Solar Bashers? heard that there is a new type of electrician doing the rounds, Domestic, Commercial, Industrial, and now we have "SOLAR ELECTRICIANS"
solar electricians are quite new. they only work after dark. during daylight hours they rest and recharge. pretty poorly on cloudy or rainy days, but in the summer months, they might manage up to 8 hours work on a charge.
I wonder where the sun shines from Pete.
Only ones I’ve had any dealings with were from Latvia or Lithuania. Began with an L anyway.
How to run wiring through metal trunking into plastic isolators.
Cut an elongated cross into trunking with an angle grinder, cut along the two long sides of the cross, bend the other two sides into the trunking out of the way, place two isolators over the cross so the hole can’t be seen, fix isolators to wall.
How to run six 35mm2 5 core SWA cables across ceiling.
Fix slightly too large caddy clips to side of girder, use plastic tie wraps to hold cables to caddy clips.
Reply to Adding extra double socket to garage in the DIY Electrical Advice area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
