Adding fused spur for bathroom extactor | Page 3 | on ElectriciansForums
Discuss Adding fused spur for bathroom extactor in the UK Electrical Forum area at ElectriciansForums.net
UK
Hi - I'm planning to fit an extractor with timer to a bathroom, switching on with the lights and had bought a fan isolator switch, but reading the Manrose instructions they insist on double pole fused spur with 3A fuse.
I think it will be easiest to fit a switched fuse spur and not bother with the fan isolator - this will be fitted outside the bathroom above the doorway.
Just figuring out the easiest way to fit this in since the extractor needs live and switched live.
Current setup
[ElectriciansForums.net] Adding fused spur for bathroom extactor
Suggested:
I have also seen options that suggest to use a double pole pull switch instead and then only the extractor fan is protected by the fuse - suggestions?
Regardless of whether a MFT or AVO8 is used, I think we can safely say that nothing like any testing is going to be carried out for this diy job.
Course you are right but its most probably a class 2 plastic fan off a light circuit so realistically what would you expect him or any one to test, no disrespect intended
The existing circuit for suitability for alteration as well as the required tests for the alterations.
He was also on about adding in a FCU and fan isolator.
Just to clear this up - obviously highly skilled task, with specialist equipment needed. What specific qualification/certificates would any prospective electrician doing the job need to have and I'll make sure to check?
H
Hes connecting a fan to a light, as long as he is reasonably sensible he will be fine. Sometimes it' easy to be over petantic
And I'm in jamacia and drunk so I shoulnt be doing this so I need to move away from the forum, love you all x
Reply to Adding fused spur for bathroom extactor in the UK Electrical Forum area at ElectriciansForums.net
