Adding in sockets | on ElectriciansForums
Discuss Adding in sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sam6555
Hi, behind my TV I have just 1 single socket on the wall. I was thinking of adding a double or 2 there and I don't think the end of the ring would stretch into a second box next to it. Would I have to add in a fused connection unit in there for the 2 ends of the ring to go into, then link the sockets in radial from the FCU.
you can add 1 double on an unfused spur. much easier to plug in a 4 or 6way extn. lead.
So I should just swap the single for a double then add the second double as a spur from that? The sockets/backboxes/FCU were already bought.
if the single existing socket is part of the ring, yes. swap for a double, and spur off to another double. no need for FCU.simmples
My solution rented house FCU where old fire was fitted dual box 2 fcus with 4 way extensions mounted under tv shelving I hate going to my M8s where he has 4 4 gangs daisy chained every outlet used New house is getting MK multi gang multimedia thingy as phone/sky will be new might as well make a job of it and have it all nice n prity
Reply to Adding in sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Outside socket… ok. But you say the fcu for boiler is beside the outside socket… is the boiler outside too? FCU’s have an IN and an OUT… the OUT...
An example of the long term race to the bottom of quality of work in our industry, IMHO.
