Adding lights to circuit with no CPCs | on ElectriciansForums
Discuss Adding lights to circuit with no CPCs in the Australia area at ElectriciansForums.net
H
harrymonkfish
Hi there.
I have been asked to add some downlights to a lighting circuit with no cpcs.
The circuit is rcd protected and he wants elv lights.
Can i just add them because they are elv or do the same rules apply as for lv?
any suggestions greatly appreciated.
harry
Indeed, but the cable does.
Haha! - not on the secondary side :p
In Pushrods defence, i wonder if he`s envisioning the situation to be simply taking the switched live, from the original fitting, straight to the tranny. In fact, theoretically its conceivable that it could be done without really disturbing any of the original wiring - & purely adding a Safety Isolated sub-cct (i assume Harry left the S off the ELV by accident)
Not seriously suggesting he should do it, but must admit i`m visualising how the conversation would go with Ray or Steve on the techline :rolleyes:
I guess you don`t have to ring em to often Mr S - they call you :)
reg 411.3.1.1
A CPC shall be run to and terminated at each point in wiring and at each accessory
I saw this reg the other day, but didnt give it much thought, as I presumed it related to a conventional 3 plate system.
Does this mean that I cant run a 2 core to a double insulated (or more likely a 12volt) light fitting, but instead have to run a 3 core, which will be conected to nothing?:confused:
The only benefit I can see for this is for testing/fault finding.
Not arguing with anyone, just cant see the point, unless its for future use of course.
Through the neutral?
Not meaning to sound stupid or argumentative, its something that I have given thought to in the past, but didnt realise that there was a particular reg for it.
Are we saying that you cant use any 2 core cable for anything above selv?
Going off on a bit of a tangent here, and not really helping the OP
Also, this may be a little random, but I vaguely remember this question coming up at a course somewhere(it may have been on my 17th edition course). The answer given, IIRC, was that if you had plastic boxes i.e not metal knockout boxes and plastic light fittings, then you could get away with not having a cpc on the lighting circuit. In my experience though lecturers aren't always right......
I have an old chestnut for you......what if the light fittings are not accessible simultaneously with an exposed conductive part?
I think I will manufacture and market 1.5 kVA isolating transformers for old lighting circuits :D
reg 411.3.1.1
Indeed it should - if ADS is used as the means of providing basic & fault protecction
But, of course, that isnt the only form of `Protective Measure` we can utilise - else we`d be a bit restricted wouldn`t we :eek:
Others we can (& do) utilise are: double or re-inforced insulation; electrical seperation; and the use of ELV by SELV (or PELV come to think of it)
Come on fellas, how the hell would SELV be of any use if we had to supply a cpc :D
Kinda defeat the object wouldn`t it :rolleyes:
I rest my case.....
...& me
sorry J, couldn`t resist it :)
Reply to Adding lights to circuit with no CPCs in the Australia area at ElectriciansForums.net
No to all. Also would require a means of isolation for PIV - pulling a fuse wouldn't be acceptable. I don't mean to seem disrespectful, but this...
nicebutdim
N
I have a question i hope someone can just give me a little clarification on . When carrying out preliminary cable design for a given circuit we...
