Adding sockets to RFC | Page 2 | on ElectriciansForums
Discuss Adding sockets to RFC in the UK Electrical Forum area at ElectriciansForums.net
FatAlan
Trainee
Nearly Esteemed
Supporter
Surrey
Want to add two double sockets to one of my ground floor RFCs. Was initially thinking that it would have to be a FCU to a spur. Would it be better practice to just incorporate them as part of the ring?
Sockets will be running a TV and either PS4 or Xbox depending on what FA junior is in to. Not much else on the rest of the circuit other than four standard lights in the corners of the living room and another TV with linked hifi and satellite thingy?
Going to have fun sinking the back boxes as said wall is old external so straight into brick.
I don't do second attempts. I did, though, use the butt of the butt crimp with solder before shrink sleeving it. A good joint I was content with.
Is all that tape and butchered crimp on the floor from your first attempt ;)
Tape was from the screw terminal whilst I was chasing - Hey, why am I explaining myself to you!
Neat job apart from the oversized sleeving which don't fit up into the connector.
you try getting smaller earth sleeve from wholesalers. anyway, the sleeve is well up to the wago, just not inside it. so ner, ner. :p
Westwood has been the only one mentioning in the past about 2mm sleeving and going up to 4 or 6 mm T+E's CPC, when I see it on an old install it always looks so smart. I've just got to use my 94 metres of 3mm before I get some!​
I spent ÂŁ5 on some 2mm just to get some peace :rolleyes:
crimps are colour coded according to size. red = 1.5mm, blue = 2.5mm, yellow = 6.0mm. suppose theycould do the same as with fire extinguishers and put different colour rings on them, just to confuse us, like the new standard for e/e signs. the door is below the sign, but the arrow says go up.
A down arrow is required when the route from the exit is down a stairwell.
agreed, my point was that with a sign above an exit door, always has been a downward pointing arrow. now it's an upweard pointing arrow, a bit like a road sign. straight on now being up, rather than pointing to the door.
Reply to Adding sockets to RFC in the UK Electrical Forum area at ElectriciansForums.net
