Hi
We live in a new build (2015) and the developer added Power and Lighting to the garage via a double socket (spur from house) and then a single light coming off the socket (via FS) for the garage. I then added another driveway floodlight off another FS.
Anyway, we plan to do some garden work this year including decking so I am thinking of just adding another CU into the garage which will then allow me to run a new socket circuit for the garage and the garden plus a separate lighting circuit for the garden, I want about 10-12 10w GU 10 bulbs in the garden.
I have a spare circuit breaker on the main CU in the house and I want to keep costs down so am happy to do the donkey work myself and then get a sparky in to connect it all and test etc.
Does this sound logical?
I am thinking 6mm SWA from the CU to the garage, then mount the CU ready for connecting. My only concern is that I don't want to run in the garden cabling just yet as I am not ready so could I just get the sparky to terminate the existing double socket onto circuit 1 (for sockets) and then the garage light for circuit 2 (for lights) and I can then extend these later into the garden adding lights and new sockets??
Hi
What are your intentions for the existing cable feeding the spur from the house?
I would just remove it, they have basically drilled through behind an existing socket into the garage and fitted a double socket directly on the wall.
Its an attached garage, I should have mentioned that :)
The first bit sounds logical, I'm not quite sure what your suggesting for the second bit?
Your new proposal, will require notification to your local building control. A scheme registered electrician would be able to carry out the work, and include certification & the notification. Its a bit pointless discussing size of cables etc, leave this to the electrician carrying out the work.
I suspect the existing cable installed will be swa & suitable for your intentions, but best left to the electrician to decide. You may be able to help with installing a new one, if required, with the supervision of your electrician (I don't like digging trenches myself). The rest is best left to your electrician.
Basically I am not ready to get power to the garden yet as I want to do it at the same time as the decking so if I get the sparky to get the existing garage socket and light onto the new CU, could I then just run power and lights to the garden later in the summer myself.
The garage is attached so it needs a new cable from the CU, I figured SWA as the route would need to go outside the house to get to the garage as I have no desire to cut open walls etc.
Fair enough, I suppose it won’t be hard to find a newly qualified spark who is happy for some private work. £100 for a couple of hours of testing and signing off is not a bad little earner.
Hi
Why not ask Starjack, he seems to know it all.
Why not just pay an electrician to do it all, you can't just pick a cable size without calculating volt drop etc, the electrician might let you dig and backfill any trenches etc but leave the rest to him.
I’m a newly qualified sparky, but I’m not that desperate for work, to go test & sign off on a diyer’s own electrical work, without seeing it all done with my own eyes.
I’ll be more than happy to test & sign it off for you if I can come over and just sit there and watch you do all the work (under my supervision) for £50 + VAT per hour.
Turns out I have a sparky in the family, agreed I can run all the cables, mount the CU etc and he will just come over to connect the cables up and sign it all off.
Happy with that, at least I know getting future work done around the house is going to be cheap!
Kent
Additional CU in Garage for Two Circuits?
CiscoKid,
CiscoKid,
