Discuss Additional protection regulation in the UK Electrical Forum area at ElectriciansForums.net
So a 16a radial with one socket requires an RCD?
Yes. Why wouldn't it?
So as long as you haven't barried the cable the wall less than 50mm , and its not a domestic inviroment then i would way say part b of this reg covers what you have done as compliant
I did think that justvafter posting it i was under the impression that there was no exceptions for omitting an rcd in a domestic environment athough now i re read the reg it does not mention about it being a domestic environment so i stand correctedSurely exception b applies irrespective of the use of the building?
One point I would like to make:
A documented RA which does not conclude that RCD protection is not required, would not be acceptable for ommiting RCD protection.
Reply to Additional protection regulation in the UK Electrical Forum area at ElectriciansForums.net
