Tilly
Hi guys, thanks for the add.
Alarm is quite a few years old, no problems until recently.
The PIR in my shed started playing up, couldn't find the problem so it was was omitted. After a couple of bikes and a boys 360 was stored I became worried, so started to check the wiring out.
The pir wire was routed across a door threshold. I lifted the carpet to find the wire quite chewed up.The alarm was put into engineers mode. Because of the rather long route with twists bends the chewed up part was cut out, and replaced using small block connectors. A nice deep groove dug out to place the new wire in.
After the PIR was re added and alarm reset Oops ! No conformation beeps. Also the alarm will not set. Anti tamper also seems dead.
Fuses and connections all appear fine.
Help please .... My alarm is now out of action
