Adiobatic | Page 2 | on ElectriciansForums
Discuss Adiobatic in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have it on a PDF......too large to upload here though.
PM me your e-mail if you like and I'll send it on.
Re: Adiabatic
Please confirm my calcs and methods, am calculating to confirm correct selection of csa for cpc
Line and neutral csa is 2.5mm^2 and csa of cpc is 1.5mm^2
Singles in conduit from a Eaton MBH120. This is a 20A MCB rated for short circuit current of 10kA.
Zs has been measured at 0.24ohms on 230V nominal supply.
Assuming k=143 and looking for disconnection time of 0.1s
Using the adiabatic S=sqrt(I^2t)/k and calculating from the above measured values:
PEFC = 230/0.24 = 958A
S = sqrt(958^2 * 0.1)/143 = 2.118 which indicates required csa of cpc = 2.5mm^2
Now using manufacturers data from tables provided:
PSSC = 10kA (because mcb is rated for this)
According to tables for 20A mcb with PSSC of 10kA the I^2t value is 33000
S = sqrt(33000)/143 = 1.27 which indicates required csa of cpc = 1.5mm^2
So is the use of 1.5mm^2 for the cpc correct?
Manufacturers data can always be used.
Indeed when I did my 2400 we were encouraged to look it up and use their figures as it makes for a more economical design (only after we had done all the adiabatics though):rolleyes:
Reply to Adiobatic in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a Hoover HBCP3150, integrated fridge freezer. Probably 3 years old. It's immaculately clean inside and out. It looks brand new but the...
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
