X
xanderfh
Fantastic job, I am tendering for a similar job at the moment - where did you put the string fuses and did the DNO require you to install a relay as you used TL inverters?
String fuses are needed and are built in to the inverter (optional ££ extra on most of the SMA TP range) makes install simpler and neater.
Steve,
Same as any other, unless you're using a dedicated G59 relay, then it's a simple case to test all the parameters that the relay should trip on (and not) at the same time as having it witnessed (over / under volatge, over under frequency, time to trip etc all as per the G59 spec). - Best to get a specialist firm in to do the testing unless you've giot a spare £11k to buy the testing kit. Usual charge about £500 / day plus another £500 or so for the DNO to witness the tests.
Then we will probably invest in the test equipment, on further projects, and do it ourselves then.
Reply to the thread, titled "advice for 3 phase connection" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
