Hi all
go easy on me now!
Basically at this factory Iv started to do some maintenance for we have got a 3 phase sewage pump,with two float switches and a alarm float switch.
this is a new install as such, an electrician prior to me has run the cables for the pump and float/alarm
On the incoming end we have an adaptable box with a 3phase 240v 20a contractor in and a auto+ hand switch
The previous electrician hadn't made off each end so it's down to me.
the alarm side is in a separate adaptable box and isn't a problem.
basicaly I'm struggling to see how it can work using both float switches switching the contactor,through one contactor as I can get it to work with the two float switches through out but not auto and hand?
Please could ups anyone point me in the right direction as not had much experience with this sort of thing really!
Will add photos shortly
go easy on me now!
