advice needed re electrician problems | Page 2 | on ElectriciansForums
Discuss advice needed re electrician problems in the DIY Electrical Advice area at ElectriciansForums.net
save pics to desktop in low resolution. then upload to forum using the insert image icon.
You should be able to attach images to your posts. If you're using the quick reply text box click this button [ElectriciansForums.net] advice needed re electrician problems then under the 'from computer' tab click choose, a browse window appears so you can find the image on your PC, once you have done that the 'upload file' button will attach it in-line in your post.
Your images need to be <200kb because there's a size limit.
its not even opening up the window to upload a file now. could I email them for u to add, sorry to be a pain, ive tried to add a pic of me in my profile and cant, what a carry on, thx
has anyone seen these pics on instagram, ive looked and my pics are around 2.8 mb no idea how to make them smaller unless cropping it does that
  • [ElectriciansForums.net] advice needed re electrician problems
I see you manage to attach some photos but 2.8mb is way too big for the forum board. You can use any basic picture editor to resize them smaller. As I previously mentioned 200kb is a sensible size.
pictures above show the mess they left, some of the sockets looking a mess, kitchens 2 not same height, floor boards cut in wrong place and nothing underneath them so anyone standing on 1 would go through the ceiling . im trying to add more
im sorry not sure what im doing are these no good then, looks like its 220 kb accordin to size above
the left pipe running in bathroom that went through my new kitchen ceiling, put spot light random and looked a mess no pattern had to re do it all, my pulley cord in bathroom was about 20 ins from wall so plasterer had to remove it, not one thing have they done right, they have broken the fitting around my lounge light, the left wires under rsj and plasterer refused to t put boards over it, so that had to be all re done, been a total nightmare and now they have said their work is fine , other workers should keep their noses out of their work and I have no reason to complain and im the problem not them , and they are not coming out to finish work or give me a cert now
Reply to advice needed re electrician problems in the DIY Electrical Advice area at ElectriciansForums.net
J
Electrician Electrical shower problems Electrical shower problems I have installed a new shower and when the dial is turned to economy the light...
Johnales
J
The second photo is partly obscured, but enough to see this is a typical Volex board, where the RCD circuits are on the RH side, and the bus bar...
