Advice Needed - Wiring 4 Downlights | Page 2 | on ElectriciansForums
Discuss Advice Needed - Wiring 4 Downlights in the DIY Electrical Advice area at ElectriciansForums.net
Hi Telectrix. As it stands that top block is the first 'flow' connector for the first downlight. I could add in a junction box of some sort before hand to reduce the number of connections in this connector I suppose.
if there's adequate room, you can use the 1st connector as a JB.
Reply to Advice Needed - Wiring 4 Downlights in the DIY Electrical Advice area at ElectriciansForums.net
Thank you, it is always good to hear another suggestion :)
Thanks will give that a try in a little while Cheers Writing to say thank you very much for that advice, its worked! Really appreciate the help
