Advice on Bathroom Extractor - Potential Job | on ElectriciansForums
  • If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
You're viewing the old forum category for electricians jobs. That's fine and you can reply to threads and contact the person who posted the jobs etc too. But for new electricians jobs post to the new job forums instead; Electricians Available for Work Post Here, People seeking domestic electricians post here, People seeking Commercial or Industrial Electricians post here
Discuss Advice on Bathroom Extractor - Potential Job in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Northampton
Hi there,
Thought I'd post this here before I go ahead trying to hire someone, when it's something I can do myself. My bathroom extractor has packed up (seemingly). Very limited knowledge of electronics so don't want to start taking things apart. I can't tell if this piece of material is jammed in the fan in the attic and don't want to remove it and potentially start breaking things. Cleaned out the two vents in both bathrooms and both were well clogged with dust. Could someone advise me on how to proceed?
Kind regards,
R W-M
[ElectriciansForums.net] Advice on Bathroom Extractor - Potential Job
isolate supply. unclip ducting from fan, if you can access the fan blades see if they're free ( using a thin driver). if they are free, restore power and switch fan on, see if it runs or not.
Strictly speaking, it's bathroom work so you need a qualified sparky. Either way, make sure it has a 3 pole isolation switch. If doesn't, then you will need a sparky to isolate it before you go poking your fingers in it.
could you let us know if the insulated ducting is part of the fan make up or if that is doing something else. wherever possible I try & use rigid ducting even if it means covering in insulation in cold space (loft), flexible ducting is ok on small runs but you mostly always get that type of dust & mould issues from having it installed. I personally would not bother cleaning out the white flexible duct I would replace with a new bit unless can be replaced with rigid.
Reply to Advice on Bathroom Extractor - Potential Job in the Electricians Jobs area at ElectriciansForums.net
    • Friendly
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
It's actually not as those are accidents outside of work, if you suffer an injury whilst working for someone else or doing private work then...
davesparks
Electricians Jobs, Electricians Mate Jobs and Electrician Apprenticeships
Thanks for visiting ElectriciansForums.net, the worlds largest electrical and electricians community. This area of the website is for those who are looking for electricians jobs, electricians mate jobs, or electrical apprenticeship schemes. We have opened up our website to the world after being UK-only for more than 10 years. We now have jobs posted to the forum for domestic, industrial and commercial electrical work from all over the world. Anybody is welcome to register to our forum for free. You can post jobs you have going, or know of. And you can also post to the forum if you're looking for employment or recruitment. Full or part time. Just let us know the full details of the job you have on offer or are looking for and we'll do the rest.
Also note that we have tiling jobs, and plumbing work too.
