F
freedomrun
Lighting CCT has no CPC present in a domestic install i'm working on (IR test is compliant for N-L), the customer is aware that the circuit does NOT have to have a cpc installed to each light switch and fitting, but wants those CLASS 1 types present to be replaced with CLASS 2 type. Just want some advice on what others use with regard to CLASS 2 fittings & switches (such as model type best price and so on). Cheers.
