Advice on light switches and fittings to use on lighting cct without cpc | Page 2 | on ElectriciansForums
Discuss Advice on light switches and fittings to use on lighting cct without cpc in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Agreed, the circuit would still be non-compliant - but by following what has been outlined here in the previous posts, i have made the circuit as safe as i can. I will note on my EIC that non-compliances are present for the lighting circuit in question and what i have done to make it as safe as possible to the customer - without connection of a CPC.
Reply to Advice on light switches and fittings to use on lighting cct without cpc in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
The manufacturer has stuck a label on the baseplate, its clear to see. I don't know what instructions came with the fitting or what was written on...
2 3
