Discuss Advice on re-joining two main cables after patio door installation in the DIY Electrical Advice area at ElectriciansForums.net
Jamie,
Have I got this right:- It was a ring final circuit which has been split and you are now taking one leg to each side of the new patio door, and completing the ring with a new length of cable between the two?
You mention using recessed metal back boxes to contain the joints, with a blanking plate to finish.
Why not use single sockets at these positions to terminate the RFC cables, then spur into back of your proposed outdoor socket?
Apologies if I have misread or have duplicated a suggestion.
Those are sensible suggestions,if it is assumed the ring is a ring,and intact
The op is not an electrician and the likelyhood of the circuit having been tested for addition or alteration will probably be nill
It is the lack of testing and the "stuff the cables anywhere" practices that will probably have disuaded anyone from giving much advise
He seems to have researched some of the practices that would be required,but he tends to give the impression of being well out of his depth,hence why there is reluctance to aid the op
I don't agree this forum should be here to help how public do electrical work. I think it should be for sparkles to discuss problems amongst themselves, otherwise, we're just shooting ourselves in the foot aren't we?
God help us. Mods why isn't this in the DIY section.
In fact why don't you "restrict" all new members to the DIY section, then they can earn their stripes and move into the main forum....
Reply to Advice on re-joining two main cables after patio door installation in the DIY Electrical Advice area at ElectriciansForums.net
