Advice on re-siting a consumer unit | on ElectriciansForums
Discuss Advice on re-siting a consumer unit in the Australia area at ElectriciansForums.net
C
Capn Ahab
So, passed my 2391. Get in. :punk:
Have now got a job to replace a consumer unit and wire up a couple of water heater circuits that I will use for my assessment to join a comp persons scheme (I'm thinking Elecsa).
The job is pretty straight forward, apart from the fact that the CU is under the kitchen counter next to the washing machine. Customer wants it moved up about 1.5 metres on same wall, which means it will be about a metre away from the kitchen sink. She also wants tails from the isolator chased into the wall from point of entry.
My questions are this:
1. Given that I will probably have to extend a load of circuits to get them to reach the new CU location, what is the safest way of doing this that complies with the regs?
2. Is the location ok? It's not a special location, but would it be advisable to get a CU IP-rated to withstand splashing, or cover the CU in some other way?
3. The only protection on the supply tails is the distributor fuse, and cable buried in walls need to either be 5cm deep or mechanically or RCD protected, so I'm guessing this idea is a non-flyer. Anyone advise me different?
Thanks!
1. Given that I will probably have to extend a load of circuits to get them to reach the new CU location, what is the safest way of doing this that complies with the regs? Crimp and extend is perhaps the easiest way, IMO the best way would be adaptable box with din rail and connections
2. Is the location ok? It's not a special location, but would it be advisable to get a CU IP-rated to withstand splashing, or cover the CU in some other way? Why would someone even consider having a CU in the open in the kitchen. Try and get her to cover it or box it in.
3. The only protection on the supply tails is the distributor fuse, and cable buried in walls need to either be 5cm deep or mechanically or RCD protected, so I'm guessing this idea is a non-flyer. Anyone advise me different? SWA, MICC or steel plate
Thanks!
Get a new customer
Get a new customer
Who has a supply of compliant customers ready to do exactly what they're told then and how do I get some? Lol
Cheers for the advice, I thought steel plate would be the way to go. As for the location, I last spoke to her a month ago and it was up the air until she emailed me with what she wants a couple of days ago. Think I may have to visit again and be persuasive....
beg to differ. kitchen is not a special location, but according to part pee, work in a kitchen is notifiable. it's ony BS7671 that defines what is, and is not , a special location, not the building regs.
Reply to Advice on re-siting a consumer unit in the Australia area at ElectriciansForums.net
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
