C
Capn Ahab
So, passed my 2391. Get in.
unk:
Have now got a job to replace a consumer unit and wire up a couple of water heater circuits that I will use for my assessment to join a comp persons scheme (I'm thinking Elecsa).
The job is pretty straight forward, apart from the fact that the CU is under the kitchen counter next to the washing machine. Customer wants it moved up about 1.5 metres on same wall, which means it will be about a metre away from the kitchen sink. She also wants tails from the isolator chased into the wall from point of entry.
My questions are this:
1. Given that I will probably have to extend a load of circuits to get them to reach the new CU location, what is the safest way of doing this that complies with the regs?
2. Is the location ok? It's not a special location, but would it be advisable to get a CU IP-rated to withstand splashing, or cover the CU in some other way?
3. The only protection on the supply tails is the distributor fuse, and cable buried in walls need to either be 5cm deep or mechanically or RCD protected, so I'm guessing this idea is a non-flyer. Anyone advise me different?
Thanks!
Thanks!
