ADVICE ON TT OR TN-S FOR OUTSIDE SOLAR CABINET | on ElectriciansForums
Discuss ADVICE ON TT OR TN-S FOR OUTSIDE SOLAR CABINET in the UK Electrical Forum area at ElectriciansForums.net
J L
Sheffield
Please see attached diagram, can someone advise on if this TT connection is correct for an outside solar metal enclosure as shown in the diagram? If not what are your recommendations on how you would do this please?
  • [ElectriciansForums.net] ADVICE ON TT OR TN-S FOR OUTSIDE SOLAR CABINET
As above - the armour needs connecting at least the supply end so ADS occurs if someone sticks a spade through it.
Are there any good reasons not to use the perfectly good TN-S earthing for the inverter?
If people are going to do tribal dances in the rain with bare feet while laying sacrifices on the cabinet you could add a local rod as an extra precaution.
Reply to ADVICE ON TT OR TN-S FOR OUTSIDE SOLAR CABINET in the UK Electrical Forum area at ElectriciansForums.net
Good point, I was assuming an up-front RCD is for fault protection within DB, etc, and to cover for a failed RCBO for fault conditions, not as...
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
