Advice please on lighting for a workshop. | Page 2 | on ElectriciansForums
Discuss Advice please on lighting for a workshop. in the UK Electrical Forum area at ElectriciansForums.net
pirate
Supporter
Glasgow
I would be grateful if some of you could assist me with selecting appropriate lighting. Yes, it's for this Men's Shed again, sorry...
Basically, I am looking at these fittings
LEDlite LED Modular 1200 x 600 - https://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/LEDlite_Modulars_1200/index.html
Nor sure which colour temperature to go with, but that's not my main question. I need to know how many I need to provide enough lighting for our workshops. We have 2 big workshops and 2 small ones. The big ones are the same size, and the small ones are also the same size, about half the size of the big ones. I think we need something like 75 lumens /square metre?
I have tried to find a calculator, have contacted the only distributor, TLC, who told me to phone the manufacturer who told me they would get back to me soon, but I really need to crack on.
If anyone can tell me what I need for the big workshop size, I can guess the rest! Of course, I can add extra if necessary, but I would like to do one installation and that's it.
The big workshop is 10m x 3.3m and the ceiling height is 3m. I need the light intensity to be sufficient for working at benches with a lathe and pillar drill and hand tools etc and also for the kitchen area. I have guesstimated that I would need 8 units, in four banks of two, evenly distributed along the ceiling. Task lighting can be added also, if required.
I would like this to be bright, obviously, and would prefer not to over-light the space because I don't want the added hassle of dimmers.
Also, if I may ask your opinion on another point, these modules can be fitted with accessory kits to provide emergency lighting, thus obviating a separate circuit and units for that. Has anyone used these? It seems like a neat solution.
Thanks in advance, as I know some of you will have experience in this.
Naturally, any other suggestions would be welcomed!
Oh, and on the lighting side, I got no reply from the manufacturer yet as their lighting guru is on holiday, and TLC referred me there as they couldn't assist...then, looking at the 600 x 600 50W panels, the newer version, there is a "How many do I need?" rough guide table under "Technical"...DOH!
I'll let you know...with some pretty pictures too!
I'll go and take a look at that, thanks!
Re emergency lights, going for the add-on modules, maintained fittings. It's a very small space, many windows, 3 exits...no real problem being all on the one, ground floor, level.
Reply to Advice please on lighting for a workshop. in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
If it is TT then you can use the armour of any of them as CPC but will almost certainly need an up-front delay RCD at the sub-main feed point to...
