daylightsolar
Thanks Dansk, much appreciated.
Check out this .
Hallclip - no more lead wedges for flashing
(i'm not affiliated in anyway - he's a roofer who has got a neat solution).
Cutting the slate and lead flashing is good as well. This is what we used to do. Only problem is getting that slate secured above the bracket again. but is definitely a good solution.
but Hanger Bolts... on a slate roof... bloody hell.. never... would be carnage.
Those flat brackets have to go under the slate not on top. you won;t beak the top slate but the ones under will break cause you've got the void between the slate and the rafter where the batten sits. you can slow the drill right down, but any movement (wind for example) and the slates below will be gone. Meaning any rubber disk will be doing nothing, and teh bracket will move towards the roof.
Get a proper roofer to do the job. Otherwise you can kiss goodbye to the ROI.
Pics show u wot they look likeCould you post photos please. What sort of price aswell. Thanks
Reply to the thread, titled "Advice please. Slate roof installation" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
