M
Markcastle
Hi all, I was hoping to ask a couple of questions and take advantage of your collective knowledge and recommendations.
If this is in the wrong forum please move.
I’ve recently moved into a new house, as part of the sale the vendor had the old fuse board replaced with a new consumer unit (CU). The work was carried out by an approved electrician and the vendor was issued with a certificate, on which it states that the supply to the shed (6 sockets and 1 light) has been disconnected due to fault readings and advising that further investigation is required in order to reinstate. Other than that the rest of the installation was fine.
The shed is supplied by a single cable (2.5mm2 by my estimates) running approx 10m underground in protected housing from the CU under the stairs, this terminates in a 2 way fuse box (MEM rewirable type, 5A for light and 15A for sockets) with main switch. This then feeds a single light and 6 sockets on a radial circuit. I checked the live supply before the fuse box in the shed and there is no current, I also checked the fuses and rewired the 5A one.
I then moved onto investigate the CU, it’s a British General one with 2 RCD’s and 10 MCB’s (6A, 16A, 32A and 40A). There are 6 MCB’s in use and labelled (shower, cooker, alarm, sockets, up lights and down lights), there is also one more MCB with a live wire attached but no label, the screw connecting it to the Busbar is also not tightened at all. What could this MCB be for?
I also found a single live and neutral pair (2.5mm2 estimated) taped together and pushed behind the other wires in the top of the CU. Could this be the disconnected supply to the shed? I haven’t been able to trace the supply back from the shed so I’m unsure. Would this be the way an electrician would leave a circuit that was disconnected from the CU? If these wires are the supply could I reconnect them in order to check for certain? If so how would you recommend I do this (use the 16A MCB etc)?
As the circuit displayed a fault I understand why it would have been disconnected, are there any tests that I can do myself that might identify the fault?
I hope that I’ve supplied enough info; I’d really appreciate any help you could offer.
Mark
Mark
