ADVICE PLEASE - SURFACE CONDUIT SYSTEM FOR REWIRE 3 BED SEMI FRC | on ElectriciansForums
Discuss ADVICE PLEASE - SURFACE CONDUIT SYSTEM FOR REWIRE 3 BED SEMI FRC in the UK Electrical Forum area at ElectriciansForums.net
marconi
Mentor
Supporter
London United Kingdom
I am heading off next week to visit my parents (84 and 83). They live in a nicely decorated and carpeted 3 bed semi with original wiring from 1965.
I noticed last time I visited they have the dreaded green goo in the 7/029 wiring. The 1/044 lighting does not have it. They only have one or two single un-switched sockets in each room apart from kitchen and side extension which are all new and on separate circuits to the original sockets.
The advice I am seeking is on a good, neat, easy to install surface conduit system to contain wiring for new radials/rings upstairs and downstairs in the 3 bedrooms, hall, landing, lounge and dining room. I can then present it to my father and explain the benefits and ease of installation. Neither would cope with floorboards being lifted and walls chased. He is a chemist and read what it says about green goo so I don't need to convince him it's time to re-wire and at the same time to add more handy sockets higher up.
But wouldn't surface trunking/conduit make the place look tacky/nasty???
Difficult to say Mate without eyes on the house, my choice would be PVC trunking, but as Spoon said it will not look nice in a domestic setting, but definitely trunking over tube any day, where do they live?
I remember years ago, we rewired some flats that had concrete ceilings. We used cornice trunking....
[ElectriciansForums.net] ADVICE PLEASE - SURFACE CONDUIT SYSTEM FOR REWIRE 3 BED SEMI FRC
....although we chased the wall upto the top, then fed cables through back of trunking, but as shown you can get adaptors for drops to points.
Given the age of your parents it may be worth thinking about just living with it if test results are satisfactory. In my experience it rarely causes any real problems. New accessories if contaminated, and a clean up might be enough to nullify the problem for the time being. A surface rewire will be a short term solution in reality and will always look cheap however it's done.
Your chemist father doubtless understands the nastiness of the Dioctyl Phthalate, but a surface rewire will leave all that in place anyhow won't it?
If it's dripping out of the fittings (that does happen) I can understand the point, but though the cables get soft and a bit vulnerable in the areas it collects (bottoms of vertical runs mostly), in my experience they don't fail IR.
- Wear gloves and don't handle it!
Reply to ADVICE PLEASE - SURFACE CONDUIT SYSTEM FOR REWIRE 3 BED SEMI FRC in the UK Electrical Forum area at ElectriciansForums.net
C
Small rental portfolio advice please. With the up and coming Renters Charter, its probably time to start thinking about increasing the efficiency...
Chris Taylor
C
