Advise on a new 4 wire ceramic cooker hob | on ElectriciansForums
Discuss Advise on a new 4 wire ceramic cooker hob in the UK Electrical Forum area at ElectriciansForums.net
Uk
I have just bought a new cooker hob which has 4 wires however my connection points only has 3 connectors do I connect 2 of these wires together in order for it to function properly or would I need to buy a new connection point with 4 pins on. I will more than likely have to get an electrician in but if there is a new part required I would need to purchase it beforehand thanks
There is a blue and white wire connected together a yellow and green a black and a brown one also but I've just found out that the actual cooker connection is no longer live and I only have an actual plug socket beside it
time to call an electrician. whereabouts are you? a member maybe close.
Reply to Advise on a new 4 wire ceramic cooker hob in the UK Electrical Forum area at ElectriciansForums.net
I actually did it with a 4 core 4.0mm swa last week!
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
