AEG ceramic hob wiring. | Page 3 | on ElectriciansForums
Discuss AEG ceramic hob wiring. in the UK Electrical Forum area at ElectriciansForums.net
all depends on the terminals in the appliance. some use ring crimps, some just have the wires inserte alongside the screw ( with ferrukles if flex). have you got a photo of the terminals?
This is what I originally done but thought it wasn't ample enough so came here for advice. I don't know weather to use bootlace ferrules or ring crimp connectors. [ElectriciansForums.net] AEG ceramic hob wiring.[ElectriciansForums.net] AEG ceramic hob wiring.[ElectriciansForums.net] AEG ceramic hob wiring.
you could use ferrules. the terminals have a square trap plate under the screws. for 2.5mm cable use blue ones.for 4mm or 6mm use yellow. however, as the flex is terminated to the side of the screws as opposed to under the screws, as you have it in the pic.is fine. just make sure that they are tight.
From my understanding you can't put a 2.5mm cable on a 32a CB . I would recommend 4mm on the 32a CB or if you decide to stay with the 2.5mm you have to change the CB to 20A
This is an old thread but, there are a few ways that 2.5mm can be installed protected by a 32A breaker without falling foul of any reg.
1. fixed load appliance
2. spur from a ring final circuit
there may be others but I have had a couple of beers so not as sharp upstairs as I am in working hours.
Even after a couple of beers you are absolutely correct 😉
Reply to AEG ceramic hob wiring. in the UK Electrical Forum area at ElectriciansForums.net
It may still be wrong. Diagram shows l1 and l2 on different phases. If you put them on the same phase, you could overload the neutral cable...
I actually did it with a 4 core 4.0mm swa last week!
