Air Con for Electricians | on ElectriciansForums
Discuss Air Con for Electricians in the Australia area at ElectriciansForums.net
S
skirby
I've had 3 enquiries about domestic air conditioning so far this month. It's probably because the sun has been out for 3 days but I'm thinking that this could be a sign that I need to diversify.
Does anyone have experience of using the pre-gassed DIY units which have been around for a while and if so which makes are the best. I have some plumbing experience but don't really want to get involved with soldering and gassing up etc. as my van is already scraping the tarmac. I am Part P so doing the supplies should be the easy bit.
I would appreciate some advice.
fitted a few of these pregased units which are straight forward no soldering required.
joints are all compression and pipes are pre- set lengths.
you also need a 22mm condensate pipe which has to be piped outside from the head unit
when gassing up from main unit you neeed to check and double check with leak spray all yer compression joints as if ya lose yer gas its a real pain to get someone to recharge unit.
wiring is straight forward.
Thanks for the reply Empress.
The installation sounds straightforward enough.
I would be interested to know which make is the easiest to install and reliable.
I'm sure there are some dodgy ones around so I guess it's probably best to go for a well known manufacturer of AC units.
I've fitted a few and had leaks on the first one, major problems. Fortunately manufacturers fault so only cost my time. Made a contact with a local engineer with his vac license so any future one's he'll test and commission for me for ÂŁ30, see if you can find someone local who just services, fixes etc and doesn't install them - you might be able to find someone similar and is well worth it for peace of mind so they can check with their guages instead of just fairy liquid.
It's a very grey area, all these DIY units don't comply really as it's illegal to purge the gas into the air. They fill the external unit with gas and the internal with air, then give you a set time to open the valve for, which is supposed to release all the air and have you close it at the exact moment air is out of the system and before any gas gets into the atmosphere. This is of course impossible to do so I wouldn't be surprised if the red tape tightened up in the future.
Re where to get them from, do a quick search on the net for a centre that does air conditioning and you'll find that there's a company with a very similar name who let sparks sign up for reseller accounts, shaving about ÂŁ150 of the cost of the units from my local wholesalers. 12000BTUs very reasonable. Good luck :)
Thanks Cornburn.
I've had a look at the website and the training courses and it's given me food for thought.
One of my customers has purchased a pre-gassed unit and wants me to install it.
I'm quite looking forward to the job and will let you know how it goes.
Reply to Air Con for Electricians in the Australia area at ElectriciansForums.net
  • Solved
An NVQ is a vocational qualification and is based upon your work experience and what you put into your portfolio for your assessor to judge you...
Thanks for this reply, this has helped!! I felt quite deflated and let down by this experience (1 bad thing wont end my hopes of being a full time...
