Air conditioning unit | Page 2 | on ElectriciansForums
Discuss Air conditioning unit in the UK Electrical Forum area at ElectriciansForums.net
London
Im putting a new circuit in tomorrow for an air conditioning unit (im just doing the supply side). Am I right in thinking a standard 30ma rcd and b type breakers can’t be used with air conditioning units?
Tia
Surely its better to have it on a rcd than not? I was going to install a sub db anyway as theres no spare ways so can install a main switch and chuck the rcd
a RCD is basically to protect persons from inadvertent contact with live parts. what is the chance of this happening in this situation?
I actually have some experience with this.
totally unrelated job to put some cat 5 cable in above a ceiling grid.
put steps up, removed tile and poked head up for a look at what I'm dealing with.
my arm brushed against a piece of copper pipe and gave me a shock. not a belter but enough to make me flinch.
got tester out, 90v between earthed grid and this pipe,
traced it back to an air con unit outside, the incoming supply to outside isolator had been connected correctly but the outgoing side to the compressor had the earth connected to an empty terminal in the rotary isolator. so no earth to the unit.
Now you have inadvertently answered one of my questions to the OP.
I was going to use 70mm but haven't got enough space in the van for the drum so gonna go 10
or possibley
If your circuit is getting on for 100m and using a 32A device 10mm is of inadequate csa for vd requirements.
its actually less than 25A according to spec sheet. 10 is ok in my opinion for vd.
p.s. calcs done for swa
Reply to Air conditioning unit in the UK Electrical Forum area at ElectriciansForums.net
I went out to a couple of the diy style AC units back in the day. One I remember the PCB was showing a fault code, the technical team had no idea...
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
