Alarm help please? | Page 3 | on ElectriciansForums
Discuss Alarm help please? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
yea but dont mention A1 Omnicrom a slight high supply voltage and it went into alarm and locked out on the user
Omincron 600 and 700 is a sin word oldimer, the destaster of A1..lol....luckly before my time, But we sorted it with omnicron 800 with nvm. and advantage zx6 they became good sellers
It's now one long beeeeeep instead of a siren......hoping this is a good sign!
Ok soome it will stop and thats out for the night.
Tomorrow use the manual Phild d sent to rest, and advice oldtimer has give to replace battery and fuse.
Then we can help you set the system up again
Thanks very much indeed for the help here and the offer to help setting it back up but I think I will leave it disconnected!
Disconnect the battery on the outside sounder,disconnect the battery inside the panel, disconnect mains supply, job done, inoperable alarm. Ps put ear plugs in ears while working on outside sounder (sab)
Reply to Alarm help please? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
