I've never fitted one (or even see one).
Is it just a case of running a mains supply to the panel then everthing else is wireless, keypad, bell, sensors etc?
At it's simplest, yes. Some systems still hard wire the RKP and/or external sounder, but often have wireless options. If you are going to install regularly, it's better to use one manufacturer and get to know the kit (and the quirks) well. Wireless has come a long way, but signal strength and interference are still issues to watch. Like all systems, getting to understand the programming and possible/likely source of faults is important too. Battery life has talen major steps forward over the last few years.
Regards
When I surfing I read information : Hardwired alarm panels are less expensive than wireless panels, but they are harder to install. Keep this in mind if you are planning on doing the installation yourself. An average home installation with a hard-wired system takes min 12-16 hours. A typical wireless installation will take less than 4 hours. The wireless system is helpful.
What you want to do is fit an hybrid alarm system like the scantronic ion 50exd as you can hard wire and use wireless so if you do the full job and complete all the circuits then you can just simply add on extra radio detectors if you buy a radio expander as well and address the radio devices to the expander
Personally I would stick to wired systems over wireless. My personal choice would be the Honeywell Galaxy dimension range above all.
However wireless systems have come a very long way, and if i was asked to install wireless system or a wireless system would be beneficial due to cabling issues, Like many people have already stated it would be the Scantronic I-on range hands down!
Scantronic have been producing radio accessories such as panic buttons and signalling kit on top of radio panels for a very long time, (and are pretty dam good at it) Also being a scantronic they are easy to use, simple to set up/commission and they just seem to last forever.
Regardless what wireless system you go for in then end, just ensure you replace the batteries when the manufacture recommends.
Hybrid ion system is grade 3 or grade 2 you can choose in the programming
Only for the wired parts of the system. Wireless still falls outside the scope of grading as of PD6662:2010. and BS8243. You can grade the system as 2 or 3 so long as the majority of the system is compliant with that grade. Just waiting for the insurance companies to start the "but they broke in via a point covered only by wire free, ergo, not graded, ergo, claim fail" racket....
My money is on Texecom Premier Elite however, as a better system all round - and Ricochet is reliable for the most part if wireless is a must. COMIP connected to customer broadband (port opened in router) make for very easy fault diagnosis and remote reset from a laptop where needed.
Kit is far more competent, more programmable, more adaptable, and more flexible than iON too, I think.
alarms , hard wired vs wireless
Security Alarms, Door Entry and CCTV (Public)
hadleigh sparks,
sedgy34,
