View the thread, titled "Altering circuits to conform to 17th edition" which is posted in Australia on Electricians Forums.
R
roukel01
Hello All.
I understand that if you alter or add to an existing circuit (i.e extra sockets etc) that the circuit must conform to the latest regs before you commence work, and so for example, if someone wanted some extra sockets on an existing circuit that wasn't RCD Protected then this would have to be rectified first before any additions can be installed.
OK, what about other smaller minor works that you still should issue Minor Works certificates for, for example changing a broken light switch or a faulty panel heater? should you have to upgrade these circuits to staisfy latest 17th edition regs before you can carry out work on these circuits, or do you simply put a note in the "comments on existing installation" box??
Might sound a strange question but I'm just a bit confused as to where you draw the line on having to upgrade a system before you can work on it.
Thanks all
Its a judgement call at the end of the day.
Your invoice will clearly state exactly what you have done and should also note anything dangerous that you find in the process.
You can only recommend other repairs are carried out. You cant force them to have it done, unless you want to do it FOC.
Like Jason says, it a judgement call. If you want make certs for everything and use them as a reference on your invoice.
Regards,
Kev
But my question is this, in the above examples,do you go ahead and change the faulty accessory and not worry whether or not any remidial work is carried out, or do you bring the circuit upto standard before carrying out your repair?
Hadn't read it properly, if the socket was faulty due to Mr Conservatory Fitters work I would tell the client and also report it to trading standards and his part P body usually FENSA for them, along with photos.
This is why C&G drum it into you to certify everything - to cover your back, don't trust anyone (except mum)
Regards,
Kev
Cheers All, I like a good debate.
Its a shame there isn't anything set in stone about these things, sounds to me like we're all going about doing things a little differently to each other!!
Reply to the thread, titled "Altering circuits to conform to 17th edition" which is posted in Australia on Electricians Forums.
