We regularly install control panels and the supply is an SWA cable. We obviously install the cable and lug it onto the main breaker and neutral bar. We are building a pump control panel at the moment and are due to install next week so I went to site today for the final survey.
One thing I noticed by chance is that the SWA supply cable has solid aluminium conductors and armour. It's the first time I've encountered a cable of this construction and we don't stock suitable aluminium lugs for terminating.
I spoke to our two main electrical suppliers and have sourced the lugs but neither supplier could tell me what type of crimping tool would be necessary. These lugs are very long compared to the usual lugs for the copper cable and they're a triangular cross-section to match the cross-section of the solid aluminium cores in the cable. The control panel is fairly light duty (<150A 3-phase) but none the less I'm not keen on using our standard hexagonal shaped crimper, I'm thinking the distortion it will cause to the conductor and lug may result in higher temperatures at the connection.
Any pointers in the right direction would be appreciated.
