NVQ pack arrived last week,
Much happiness was felt until I read that there’s yet ANOTHER online exam and a few days I have to spend away from home!!
FFS why can’t they just explain in detail everything that’s required and what to expect at the beginning of the course!?
Am getting rather fed up with the chair-warming mouth breathers continually moving the goalposts!!
Ok, rant over ?
AM2 advice...
Don’t panic!
On the first day you get to practice on anything you’re not sure of.
I’d had a bit of hands-on prior to the composite install which helped a bit.
Go fast from the start.
You have 8 1/2 hours for the install, but that time goes quickly.
You can stop the clock at any time and as often as you like (at ERR I was allowed to).
You can get a coffee and collect your thoughts and plan your next step.
The order I did my circuit install:
Bonding
Light
Ring
CO detector
CAT 5
16A socket with SWA
DOL starter
Heating system
When installing the heating system, don’t worry about keeping it tidy, just get the wiring in quickly.
I had 2 hours left for the heating system. It was much easier than I expected, and several of the components are pre-wired, so you just have to connect the ends of the cable to the corresponding points in the connector blocks.
The connections can be a bit fiddly and some are a bit worn so it took a few goes to get the cable in securely.
The dead and live testing on the installation was straightforward.
C R I P P L E R
Follow that sequence and you won’t go wrong
Make sure you’re familiar with isolation procedure. I almost forgot to put the key in my pocket!
Dont dawdle through this as you only have 3 1/2 hours. Paperwork took me ages!
Fault finding was a doddle.
2 1/2 hours to find the 7 faults. Once you’ve found each fault, the clock stops and you just have to tell the tutor what the fault is and how to fix it, if correct then you just have to write it down on the form
Online exam was alright. Open book. C&G say “clean book exam”, but we were allowed to use our own.
Good luck!
