Am2 correct installation of data cable | on ElectriciansForums
Discuss Am2 correct installation of data cable in the UK Electrical Forum area at ElectriciansForums.net
X
xpepx
Hi guys
Ive never posted in the forum I'm a bit of a lurker and always been able to find what i need in a pinch thanks to alot of you guys out there.
I have tried my best searching and can't seem to find any info on the data cable installation. Now i recently took my am2 exam and passed everything except for this.
I used the compartments in the top and bottom of the dado trunking but i think i didnt install the plastic separator properly as ive never done this type of cable.
Can anyone show me a picture of how this piece should be installed as if i were to take the exam again i woukdnt want to fail the same part again ;-(
Unfortunately I don't have a picture of one, however you get a small plastic cover and place it over the data cable where it travels between compartments.
I ran my data in the top and bottom compartments too, so its most likely the cover that failed you. Its just a white rectangle with no back on it
Thanks for the reply
I know which piece your talking about i guessed that would be it and i used it as you said.
I must have used it the wrong way round or something. One side is shallow and one deep. I placed it so it would be deep.
Hi xpepx,
Sorry to drag up an old post but I’ve just failed AM2 as well on the data circuit. I honestly don’t know where I went wrong. I couldn’t see any strain relief on the back of the cat5 socket but apart from that I feel I did everything else correctly.
Any pointers would be appreciated.
Thank you.
Reply to Am2 correct installation of data cable in the UK Electrical Forum area at ElectriciansForums.net
I guess my last post was even less direct than intended.
nicebutdim
N
