How would I pinpoint a fault on a ring circuit with very little resistances, and without any visual clues, only by measuring.
Say I have a break in neutral between db and first socket. How would I go about fault finding it?
1. I will use low resistance ohmmeter.
2. I will find that rn is not a ring.
3. I will do the Rn+R2 and whichever socket has the highest resistance the fault has to be in between the two sockets(or db) with lower reading?
Then if I have a short on neutral and earth, again between db and first socket.
1. I will do insulation resistance test between L-N, L-E, E-N on both legs and find the reading on E-N.
2. So the fault is the earth fault between neutral and cpc conductor.
3. But how will I pin point it? With the Rn+R2 test again looking for the highest resistance?
