Am2 | on ElectriciansForums
Am2
Discuss Am2 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi guys
After a little help regarding my AM2 which I have booked for this Tuesday and Wednesday. Do you test both ends on the data point or is one out of the two fine?
I had the refresher course and feel quite comfortable and confident but is there anything I should look out for or remember which is common of people forgetting/doing wrong?
thanks
Chris
Hi guys
After a little help regarding my AM2 which I have booked for this Tuesday and Wednesday. Do you test both ends on the data point or is one out of te two fine?
thanks
Chris
cat5 tester, plug into both ends with 2 short patch leads
use ready made to avoid false readings
they sell them for £10 or so at screwfix or on amazon for £3
bassically cycles through led's on both ends
Upvote 0
Reply to Am2 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
  • Solved
I don't think its right either but going into this I didn't know what to expect. I'm now thinking I would have been better off with an...
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
Electrical Courses
