AM3 Tails Stuffing gland | on ElectriciansForums
Discuss AM3 Tails Stuffing gland in the UK Electrical Forum area at ElectriciansForums.net
Gazthesparky
Glasgow
I seem to have a run of jobs of upgrading consumer units. Previously I've used 32mm standard stuffing glands for the tails when I have needed to. Although the sealing gland hasn't got specific holes for the tails i find that it seals well.
Anyway I've been looking at the special tails stuffing glands. My wholesaler is quoting alot for the metal wiska type. Looking at screwfix they have 2 plastic types. One is just the gland and one is a kit with a KEM adapter.
The only problem is that they need a 40mm hole and on the wylex boards I'm using have 20/32mm holes. So i would have to enlarge the holes to suit or buy the kit with the KEM adapter. Just wondering if anyone has any experience of these?
Just not sure because they seem massive in size any other suggestions what other people use ?
Cheers
it is only the top of the board that has to meet IP4X so go in the sides or the bottom
In all the kerfuffle that has come about before & after 421.1.201, one of the insinuations, was that the tails being slightly inflexible and after termination were being strained and working lose. An example of Mrs Muggings hanging her umbrella on the tails, was one. It's suggested, that using a bespoke gland would prevent such a scenario, be it a ordinary stuffing gland or one of these types. Of course, if you can fix the tails before entry into the CU, or rear entry (ohh Matron), then using such a gland may not be necessary, as long as the appropriate IP rating is maintained.
How would you guys ensure earthing for a metal tail gland into AMD3 board; if you dont mind me asking on this thread. Would you provide a banjo and/or fly lead/nut; or scrape off the paint for lock ring ?
Do the glands come with a 40mm banjo for a fly lead?
I think SWA glands come up that size so one of those would work I guess.
Yep It could be done but involes a bit of extra work and correct sizing of fly lead. Ive only fitted one and that was nylon; but im interested in how most other people do it because obviously i dont know.
Cheers
There is a version of the wiska unit which fits through the 32mm hole and will cope properly with 2 x 25mm and 1 x 16mm
tlc link:
32mm Tail Kit Gland - 2 x 16mm Tail & 1 x 16mm Earth Cables - https://www.tlc-direct.co.uk/Products/WKTKP32.html
Reply to AM3 Tails Stuffing gland in the UK Electrical Forum area at ElectriciansForums.net
I doubt we would be recommending them if they were not up to the job
I think a 3 legged breakout boot would be your best bet in the circumstances.
davesparks
