Amd 3 compliant, metal, two module unit | on ElectriciansForums
Discuss Amd 3 compliant, metal, two module unit in the UK Electrical Forum area at ElectriciansForums.net
polo1
Glasgow
As above, can anyone recommend a make/model of metal housing to accommodate only an rcd? I'm guessing too, that these will require a metal cover if used in a domestic setting?
Yeah, that's what I want to avoid! I do a fair bit of work in rentals, where lots of showers have no rcd protection, hence the enquiry.
The OP asked for a metal RCD enclosure not a CU! lol
Well true, but if this enclosure did not need to meet the same standards or satisfy the same regulation as CUs, he could just use a plastic one.
I was assuming this fell under the "similar switchgear" part of the regulation hence the question.
and if he's adding to an existing install then fit an insulated one!
Yeah, I was posing the question for two reasons. My understanding is that, in the situation I described above ( fitting an rcd to an existing circuit), then the rcd enclosure had to be metal, with cover. On this basis, also wanted recommendations for a suitable unit.
i can't see how a plastic/ insulated one complies ( unless others can point to other info).
Reply to Amd 3 compliant, metal, two module unit in the UK Electrical Forum area at ElectriciansForums.net
Interesting item you have there. This blog might be worth a read https://sllipblog.wordpress.com/2014/04/29/its-now-00-28am-and-i-need-my-bed/...
Yes that was me. If you change your mind give me a shout and I’ll sort something out for you 👍
