Amd 3 compliant, metal, two module unit | Page 2 | on ElectriciansForums
Discuss Amd 3 compliant, metal, two module unit in the UK Electrical Forum area at ElectriciansForums.net
polo1
Glasgow
As above, can anyone recommend a make/model of metal housing to accommodate only an rcd? I'm guessing too, that these will require a metal cover if used in a domestic setting?
most scheme providers would beg to differ.
Tend to agree, and with BS7671 being a bit vague on 'similar switchgear', who else can you ask for advice, unless you think you know better. Carry on installing stuff regardless, might make you look a bit wanting if the authors of BS7671 confirm what the schemes are suggesting.
Ok, not many suggestions then :confused5::confused5: NICEIC Tech helpline today confirmed their inspectors expect metal enclosure with metal lid (doesn't have to be self-closing) in the scenario described in my o/p, in order to comply with Amd 3.
Reply to Amd 3 compliant, metal, two module unit in the UK Electrical Forum area at ElectriciansForums.net
Interesting item you have there. This blog might be worth a read https://sllipblog.wordpress.com/2014/04/29/its-now-00-28am-and-i-need-my-bed/...
Yes that was me. If you change your mind give me a shout and I’ll sort something out for you 👍
