I have been scouring around try to get decent compression glands for the above, so here is a question that some may find an obvious answer to, what is the IP or other rating that is required,? however, most makers quote IP 68 which may well be ok as far as it goes, but do they prevent the spread of fire which is the supposed whole aim of the tin box fiasco, of course we all know its whole heap of utter crap initiated by the manufacturers to sell us more stuff and more expensive stuff at that, which we need to pass on to the home and business owners and will not ever stop one single ballsed up CU change catching fire. so what are you guys using and has any one ever had comments from your annual visit on what you use
Pict
Pict
