Amendment now problems later | on ElectriciansForums
Discuss Amendment now problems later in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
cliffed
Worcester
Doing a EICR in a college…there have been many over the years, it’s approximately 50 years old & improvement happens every so often.
The new amendment concerning all areas of the installation on support of cables to prevent premature collapse.
This college consists of plastic containment throughout its corridors & on fire exit routes.
My opinion on this maybe a recommendation C3… & noted to whom concerned, this would require major works throughout.
Some of this containment is above false suspended ceilings, most clipped direct to the concrete floor of the above floor & visible, any advice much appreciated
Agree, nothing mentioned in any other EICR’s either, about the supports, but with all the news on the cable containment, should this now be noted…
Have you actually checked the plastic containment doesn't have metal clips fitted internally throughout or is the best way forward to put it down as a limitation and as such not verified
A C3 code could leave you looking a bit daft if you haven't verified it throughout and to do that could be very time consuming
It isn't news it needs noting. I tend to take a sample inspection on a site just to check because as above you can't always see it.
It’s definitely not compliant
Yes its been up for @ least 15 years…
So you are making an assumption on the age of the installation and haven't removed all the containment lids to verify it as it would take a lot of time and risk damaging the plastic containment which often becomes brittle as it ages
The college was built in the 60’s, the plastic trunking was fixed to the concrete ceilings, this trunking & plastic conduits are seen in all corridors on 1st floor up to the 3rd floors, & also on fire exit routes from corridors to staircase.
Several EICR have been performed in the years, no mention of this, seeing the importance of premature collapse of wiring systems, what would be the correct assumption to make.
My opinion would be a note & a classification code would maybe Code 2
An EICR is IMO based on verified fact and not assumption if you cannot verify any aspect of the installation outside of the limitations then it's an FI
Whether it is a code 2 or an FI both give an Unsatisfactory outcome to the EICR so your dilemma is FI or C2
Previous EICRs can be useful for comparison purposes, but when doing your own EICR, would it not be essential for such things as the prevention of premature collapse to be verified by inspection, wherever it needs to be applied?
As has been mentioned, it may already be in place, inside the plastic trunking.
If it is found not to be in place, then a C2 would likely be warranted.
If for any reason you're not able to inspect and verify, then an FI, as UNG suggests.
Then a follow up visit would be necessary.
Definitely pre metal fixings, including all surface mount plastic conduits, plastic saddles no metal ones
Agree but this EICR will definitely be far different from the others & costly to put right.
I'm obviously not bothered about the consequences regarding the remedials thinking C2 would be the correct code.
All this premature collapse concerning cables is quite hilarious, this relates to cost & speed when the idea of a fast fix seemed great.
Remembering when I first started it was always a metal install, conduit/trunking/tray/micc/Swa etc
So what about sampling? If we male judgements based on sampling (sockets for example), we are working to assumption, not fact. We can say it would be highly probable based on said sample, either way we aren't using fact when we sample.
We're talking potential deaths here, the fact we still have discussions on premature collapse, the retrospectiveness of regs and what not is frankly, crap.
If your engineering judgement says the place is a potential death trap for firefighters then that should be taken as such - hell; include a copy of the Rule 43 letter from Shirley Towers for reference.
Would we leave insitu VIR? Even through we know damn well that by now it will be life expired based on the fact "it complied at time of install"? Would we hell, we'd strongly advise it gets ripped out and replace sharpish and use regs (and EAWR) to drive the point.
Even if they can't rip it all out, they ought to be able to retrofit to accessible sections and at least reduce the risk
Reply to Amendment now problems later in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
