An electrical puzzle
marconi
Mentor
Supporter
Attached is a circuit. It was a course problem I recently was involved with through long-term mentoring of a junior, bright member of the EF.
I thought others might like some mental fun too.
1. How much power is dissipated in R2?
2. Which is true? Both batteries supply energy? Only one battery supplies energy?
E1 = 45V E2 = 30V. R1 = 1800R R2 = 2200R R3 = 2700R R4 = 3900R
Assume batteries have zero internal resistance and are rechargeable types. Assume all wires and connections have negligible resistance.
Hint: Mesh analysis of dc circuits but there other ways of tackling this problem.
So we don't use Kirchoffs voltage law here just straightforward Ohms law then, what say you @Baddegg ? So split it into two then and getting a bit lost now come back to it in the morning when I'm a bit brighter. Might have to confer with @Badegg on this one a little though. I am a bit worried about the loops as E2 is in the middle which throws me a little but at least the current is going in the same direction and mesh at R2. Yeh let me thing about this one. Hang on we don't use Kirchoffs in the Branch current method. EDIT
I must say though, this should be in the Arms. It could cause a scandal when the general public realise the paucity of knowledge in the less educated among us running amok in peoples houses.?
Well this was something to wake up to...
Thought I would take a look whilst my coffee cools, I thought doing it by superposition would be quickest, which gives E1 as source, E2 as sink, and 4.8mW
But as it doesn't line up with previous answers, nor comes out with a nice round number as these things usually do, so I did it via Maxwell (kirchoffs ) which gives two unknowns from two equations, so just the mechanics of solving, however my coffee got to the right temperature, so just solved via wolfram!
Gives the same current, so I think it's right, unless I have made some stupid mistake - it being before the morning coffee to wake me up.
Scruffy calculations attached:
By Thevenin’s theorem or Tellegen’ theorem anyone?
Not a problem, but I would think a poor choice, if the question was to calculate the power/current/voltage of the load resistances Thevenin or Norton equivalents would be the first choice (Probably Millman would be best), Tellegen's wouldn't be my choice either - unless it was more complicated and I was using software - it's good for relatively short transmission network calculations.
My order of preference would be
Superposition
Maxwell (mesh )
Millman/Norton/Thelvenin
The ideal current methods I would use the 1800 & 2200 ohm resistances as internal resistances of the voltage sources as it's obviously not possible to get an ideal current source equivalent for an ideal voltage source.
And of course Millman uses Norton to start with.
Ahh well, back to the boring stuff, today is a work day ?
marconi,
Julie.,
TrueNAS JBOD Storage Server
