An insulation resistance test | Page 2 | on ElectriciansForums
Discuss An insulation resistance test in the UK Electrical Forum area at ElectriciansForums.net
akmal
uk
Hi,
Can some one please help me with this question:
Q: An insulation resistance test on one of the radial socket-outlet indicated zero mega ohm between line and neutral. Explain why the result of the previous R1 + R2 test could not be used to confirm polarity for this circuit.
If any one can answer this question, it will be very appreciated.
Reply to An insulation resistance test in the UK Electrical Forum area at ElectriciansForums.net
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
