Another 2391 question! | on ElectriciansForums
Discuss Another 2391 question! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
tex431
Outback, NZ
State the;
i) tests for insulation resistance to be undertaken on a 230v circuit contaning surge protection devices which cannot be disconnected. -I am i being dumb here? Phase-Neutral and Phase-Earth
ii)The test Voltage- 250V
Test across L-E, N-E and L-N, or L+N-E @ 250V, as the SPD is connected across L-N, L-E and N-E
Min resistance at least 1Meg Reg. 612.3 (BGB)
Just be careful to refer to 'E' as the Circuit Protective Conductor, 'L' as the Line conductor not phase conductor, and remember that Neutral is a 'live' conductor......City & Guilds will have you in anyway they can!
State the;
If it can not be removed then connect L and N together and test to earth @250v, note it on the test sheet as limitation.
It is for the 2391, they may, depending on the centre, want the full test sequence.
You can never tell with C&G
Reply to Another 2391 question! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
I may have been mistaken regarding TT I will look into that, thank you for the valued reply, but in general I stick to my post, a good topic for...
