Discuss Another coding question? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Bodged up hinge too isn't it?
Evening.
I am unsure whether to code this a C2 or a C3. I wouldn't normally code a crack in the meter casing as a C2, but this is a big hole right where the cut out is? Plus I'm particularly poorly at the moment with a horrible bug and have become very indecisive! :nonod:
Cheers chaps.
View attachment 31944View attachment 31945
I don't think it is within the remit of 7671, no code IMOI am not 100% as to whether this is or isn't within the remit of 7671 and an EICR. If it is, I would C3 at most. Even in a strong windy storm water will likely run out again before it can do any damage. A lot of the meter cupboard doors and replacement hinges are available online if you are likely to be doing the remedials. I have used these a few times, and they are a doddle to do. Meterboxs Direct Online Shop | Electrical Meter Box Doors
Reply to Another coding question? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
