W
walec
Hi All,
Just installed an new CU in the garage, my problem is the earthing, I used 6mm SWA with a plan to bang an earth rod in. The garage is not attached to the house and has water and gas which are supplied from the house mains. The garage is only 2M away but as it is a seperate building I thought it had to be earthed by TT for equipotential bonding of the pipes. The problem I have is I am getting a reading of 313ohms from the rod (in wet ground). So I am wondering do I bang another rod in or as the gas and water are supplied from the house can I just export the earth to the CU and ignore the equipotential for the garage as it is bonded back to the MET in the house at its origin anyway?
Any help most welcome
