Looking to install an extractor fan for a client. Issue is that they have a child that sleeps in an adjacent room and they like to keep the bathroom light on but obviously not with the fan going. The obvious solution is to switch off the fan using the isolator but this switch is going to be quite high up. They'd like it working on a humidistat rather than a timer. It will be ceiling mounted and needs to be as quiet as possible. Any recommendations / options / solutions?
Was wondering if an extractor would continue to work on the switch line if the permanent live was cut? i.e. if you put an additional switch in the permanent live after the isolator? Must admit I'm of a mind to recommend a humidistat with timer but just on a very short time setting.
